Loud noise from PSU on boot
Discussion in 'Computer Components' started by Richo_EFC, Feb 8, 2009.
  1. Richo_EFC
    Richo_EFC
    Sep 16, 2007
    194
    +4
    When I boot up my PC I get a loud humming noise form the PSU. It usually takes at least 3 restarts before it boots normally. Does anyone have any idea how to fix this? Thanks
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Try another PSU if it corrects the problem then your PSU needs changing.
    Curly
  3. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    Replace psu it is bad:( the hum you get or hear is from the windings on psu..
    throw before damage occurs on system i.e Short..
