Lotsa help please - I is a noob
Discussion in 'Home Cinema Speakers' started by JSW, Feb 21, 2002.
  1. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Need new speaker system urgently
    Like the idea of the kef egg system allthough would like the mission cinema 7 but dont really have the room :(
    My current kit:
    TV Sony KP41-DS1
    DVD Sony DVP-S735D multimodded
    Tuner Sony ST-SB920
    AMP Sony TA-VE150
    Speakers Sony SA-VE150
    Am getting rid of the amp, speakers and tuner
    and the following is arriving next week:
    Amp Sony STRDB870
    CD/Tuner/Amp Linn Classik
    Now wat i need to know is should I run the Linn Classik a dedicated pair of speakers for it off its own amp or should i run it through the Sony amp with watever speakers you reccomend???
    I want 5.1 and sub for the sony so please help me peeps.
    JSW
  2. Guest
    I would suggest you stick it through the receiver. The whole point of a receiver is to make the "centre" of your setup, with everything going through there before going somewhere else.
    Also, by sticking it through there, you can enjoy any DSP or processing, and more amplification than with the CD player.
    -TF
  3. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Tks
    But wat speakers should i get????
  4. Guest
    I would go for the missions, which is what I will be buying soon, too.
    I'm planning to mount the m72s up on the front, which saves a bit of room.
    -TF
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    JSW,
    This is an unusual setup that you are putting together. You already have a DVD player and are buying an AV amp plus a further CD player / Amp combination.
    If you connect the Linn through the Sony Receiver there doesn't seem to be much point in buying it as a dedicated CD player would have been cheaper and easier to integrate.
    What exactly are you trying to achieve ?
  6. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    av amp was allready ordered
    i came across the linn in a trade
    My main concern is not the linn but which speakers i should go for?
    The linn could end up in the bedroom.
