Lots of speaker cabling help needed!
Discussion in 'Cables & Switches' started by Fat Tony, Jun 8, 2004.
  1. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    I have a few questions, please help. :)
    1. What's the best cheap speaker cable (max £4/m) that would suit Kef eggs (2005.2's). This is for the 3 front speakers, where I will use Kef stands & rack for centre. Is QED silver anniv. (£3/m + postage from ebay) about the best I can expect? Will it fit into the centre of the stands?
    2. For the 2 rears, I need to run cable across the room & then will channel into walls. I have new fitted carpets - how do people do this or do I call a carpet layer to get them laid back down? Also do you run cable around the edge of room (longer) or do you go least distance (shorter cables, but may get people walking over them). I found below quote from Ian J - is Ixos 607 the best option or are there others?
    3. Does the length of cable of each pair of two matching speakers (fronts & rears) have to be the same?
    Sorry if these appear to be dumb questions, but I did search first! :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    1: I wouldnt spend anywhere near £4/m on Kef Eggs mate £1.50/m standard 50-70 strand will be fine mate!
    3: not unless difference is HUGE! ie 1m and 20+m
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    For a second opinion - I agree with Hornydragon. Many people seem to be happy with free bell wire or go OTT with stuff that is far too expensive for the partnering speakers.
    I don't suppose that it matters whether you run the cable a shorter route under the carpet or slightly longer round the walls so whichever is most convenient for you.
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,184
    2
    +3,647
    QED original gets a vote from this party at a max of £2.50/metre (should be less). Doesn't overmatch the speakers and it seems to last forever. It is also small and neutrally coloured. Annivesary really isn't worth it on any satellite TBH.
  5. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Thanks for the advice on cables for the front's - I was just going by the oft quoted rule of spending 10% on cables & thought I had to pay this to do justice to the speakers.
    For the rears I need flat cable to hide under carpets - any suggestions?
    Also, new question - what suggestion for subwoofer cable? I was going to get the Mark Grant one based on all the good things said here (I am happy to spend that if needed).
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    As you have already spotted, I use Ixos 607 flat cable for the M&K K4's that I have as rears and that is routed under my carpet.
    The difference in price between a cheap subwoofer cable and Mark's isn't great and if you buy one of his, that could well be the only item of AV equipment that you will never have to upgrade.
  7. Fat Tony
    Fat Tony
    May 1, 2004
    644
    +20
    Thanks Ian. :thumbsup:
    I think I'm sorted. :smashin:
  8. GAmbrose
    GAmbrose
    Jul 5, 2003
    996
    43
    Essex
    +184
    I wish you had started this thread earlier :)
    I asked some people and they all said QED silver, mine are for KEF 2005.2's and it cost me £4 per metre (arrived today)
    Could have probably saved myself £50.
    Gary A
