Quantcast
LOTR TTT WMV 720p OAR.avi Cant play in VLC player
Not had any issues with wmp.. I use it for everything TS/WM9/ etc etc soudns fine on my lcd speakers or through the avamp ?
Though I admit to not having the TTT wm9.. I only have the TS version.
Matt
Justinrog
I remember I had some problems with some films. Make sure you have the correct AC3 codecs installed, but you probably have due to the audio working in VLC. Is the dialogue the main missing component. I found I had to change my speakers configuration in windows Sound control panel as I only have 4.1 (4.1 THX though!). So play about with the speakers and the dialogue should shoot up in volume, well, it did for me anyway.
Sorry if that does not help...
J
Similar threads
