LOTR TTT EE R2 Packaging
Discussion in 'Movie Forum' started by Barrovian, Nov 18, 2003.
  1. Barrovian
    Barrovian
    Oct 29, 2002
    1,058
    United Britain of Great Kingdom
    +119
    Has anyone managed to remove the Gollum figure from 'The Two Towers' collectors edition without destroying the packaging?
    It looks like it's glued in :confused:
    I tried last night, but gave up for fear of destroying the box.
    If anyone has managed it, please let me know how you did it.
  2. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    John, you may need to go through the bottom (as with so many other things in life :D ) i found it very difficult to remove, but i did rip part of the base of the box.
    Good luck
    Gary
  3. Rochdale
    Rochdale
    Mar 16, 2002
    359
    Leeds, UK
    Same with the R1, the plastic packaging stuff around the base of the statue was glued to the box.
  4. Jpfahy
    Jpfahy
    It seems such a shame to destroy such well crafted packaging :(
    My argonath from FOTR-CE are still residing in their box (cable ties and all)
  5. adi
    adi
    i hacked about at the foam with a craft knife - there is a plastic cable ties buried in there somewhere which hold s the foam together - find that - snip it - and bob should be your uncle !!
    adi
  6. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    The R1 is the same. I took a JML kitchen knife (VERY sharp) and cut diagonally across the polystyrene in an "X" and chearing the cable tie in the process. The statue simply lifted out then. See, simple. :D
  7. Borusa
    Borusa
  8. Jpfahy
    Jpfahy
    Why they didn't package it with clear plastic and cable ties like the Argonath statues is beyond me :rolleyes:
  9. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    I also found that putting a long sharp knife between the flaps in the base of the box helps to cut a lot of the glue before you go in through the base. This makes opening the base a bit easier and the inside doesn't get too torn up.
    There certainly wasn't any danger of it coming loose it transit...I was about to look for a recipe for Napalm before I saw the sideshowtoy link.
