LOTR - ROTK - dodge import ??
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Lighty, Nov 13, 2004.
  1. Lighty
    Lighty
    Mar 7, 2002
    2,791
    East Yorks
    +130
    hi
    i have the 1st 2 on R1 and was wondering if theres anywhere to pick ROTK EE 4 dvd set up cheap?
    amazon.com have it for $24 !!!
    how do you work out tax etc if i get clattered for it?
    cheers
    sean
  2. andrew1810
    andrew1810
    Apr 4, 2004
    1,041
    Northumberland
    +54
    If it comes to less than £18 then customs isn't a problem.
    Andrew
  3. eas4uk
    eas4uk
    Oct 19, 2003
    1,508
    Coventry
    +81
    $24 US works out to £12.92 per www.xe.com which means it will go through ok - however you need to include P&P if it is over £18 with P&P included - Amazon P&P is usually £7-$8 which makes it £17.23 so you should still be ok
    However the customs/VAT/PO Handling calc is as follows:
    add 4% then add 17.5% of the new total, then add £4 post office handling and you get your grand total...
  4. whitecot
    whitecot
    Nov 4, 2000
    19
    Surrey, UK
    The customs limit of £18 applies excluding P&P. If the limit is breached the custom charges are based on the value including P&P.
    Of course this doesn't help you if the supplier quotes a single price and doesn't show the shipping cost.
    Paying using a voucher (or special discount code) makes no difference to Customs - that's still a cash payment so the value of an item is the value before the voucher. Proper sales are fine. If the supplier puts nothing C&E are free to guess what they think it is worth.
  5. eas4uk
    eas4uk
    Oct 19, 2003
    1,508
    Coventry
    +81
    Originally posted by eas4uk
    originally posted by whitecot
    which is what I said...
  6. whitecot
    whitecot
    Nov 4, 2000
    19
    Surrey, UK
    Sorry, not awake this morning. :)
