LOTR - FOTR HDTV 720p
Goose74
Hi guys - I have just noticed that the first disc for this version of Fellowship (ts) is on the BT network
The sample looks incredible.
Starburst
I use this player to playback .TS files on my windows PC.
Goose74
I would check out Suprnova and use the Azureus client
VLC is the best player.
The fact that its a transport stream is great for lower spec PC users since it is less demanding than compressed WMV9
P
pdundas
If you install the Elecard MPEG2 demuxer you should be able to play ts files with pretty much anything - including Windows Media Player 9 and ZoomPlayer (not that there is anything wrong with VLC).
Download and install the Elecard package and then go to the components manager which gets installed and untick the MPEG2 player but keep the demuxer. The demuxer is free but the player you have to pay for.
You should then be able to open the files in any directshow player.
www.elecard.com
dvdmike
where is the sample?
Goose74
the sample (and fisrt disc) is on suprnova - a BT site
This version of FOTR is not in OAR though - its cropped to 16:9 although some shots you see more than the DVD (super 35 process) There is a 1080p version which someone is discussing converting to WMV9 - here's hoping!
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
