LOTR Battle for middle earth (PC)
Discussion in 'PC Gaming & Rigs' started by Xirokx, Jan 14, 2005.
  1. Xirokx
    Xirokx
    when i start the game up the introduction plays fine when it gets to the menu screen and error message pops up that says...
    nv4_disp driver has stopped working normally please reboot computer.
    i have checked minimum requirements and im well above them i have installed latest driver for my graphics card disabled my firewall but it still seems to be happening.
    i have emailed EA games but they have not replied.
    I can run other games without any problems
    thanks for ya help!
    p.s ive also run dxdiag here are the results i dont know if this will help?
    System Information
    Time of this report: 1/10/2005, 02:11:08
    Machine name: NIMNIM
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
    Language: English (Regional Setting: English)
    System Manufacturer: NVIDIA
    System Model: AWRDACPI
    BIOS: Phoenix - AwardBIOS v6.00PG
    Processor: AMD Athlon(tm) XP 2200+, MMX, 3DNow, ~1.8GHz
    Memory: 768MB RAM
    Page File: 269MB used, 1608MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: NVIDIA GeForce4 Ti 4600
    Chip type: GeForce4 Ti 4600
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0250&SUBSYS_87241462&REV_A3
    Display Memory: 128.0 MB
    Current Mode: 1024 x 768 (32 bit) (75Hz)
    Monitor: Plug and Play Monitor
    Monitor Max Res: 1600,1200
    Driver Name: nv4_disp.dll
    Driver Version: 6.14.0010.6693 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 10/29/2004 16:50:00, 3736704 bytes
    WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: nv4_mini.sys
    Mini VDD Date: 10/29/2004 16:50:00, 2826944 bytes
    Device Identifier: {D7B71E3E-4110-11CF-F76D-2EA702C2CB35}
    Vendor ID: 0x10DE
    Device ID: 0x0250
    SubSys ID: 0x87241462
    Revision ID: 0x00A3
    Revision ID: 0x00A3
    Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
    Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
