Lost Voice Audio for DVDs in KMPlayer - help!
Discussion in 'Home Entertainment Computers' started by indiegirl, May 27, 2008.
  1. indiegirl
    indiegirl
    Sep 18, 2005
    40
    Hi all,
    I have Mediaportal running KMPlayer as my preferred DVD / video player. When playing ripped DVDs / AVI's (anything from file, really) I have no problem with the audio.
    However, popped a DVD in today and got the soundtrack; but no vocal audio. Fiddled about a bit (changing settings in AC3 and KMPlayer's Audio options randomly) and got a very low audio of everything.
    Am I missing some codecs for the DVD perchance?
    Or, is there an alternative player that I could try to see if it's codecs or KMPlayer?
    I should probably mention that I have a 3450 running DVI-out>HDMI into my TV, and a Trust 514DX running coaxial out to my amplifier.
    I can't work out what I've changed, or haven't enabled!
    TIA
  2. indiegirl
    indiegirl
    Sep 18, 2005
    40
    I did some further investigation on this, and it appears to be on the older 2ch DVDs that I lose the voice channel; no amount of tweaking the audio settings in KMPlayer and / or AC3filter seems to change this.
    Is there a specific setting for 2ch DVD tracks?
  3. Singh
    Singh
    Feb 9, 2004
    365
    +19
    On 2 channel sound tracks there is no separate voice channel!
    Have you tried a different AC3 decoder, such as the one built into ffdshow?
  4. indiegirl
    indiegirl
    Sep 18, 2005
    40
    I thought that might be the case.... obviously it's trying to decode an additional track that doesn't exist...
    I'll have a play with it and will try FFDShow too. It's going to be a pain if I have to switch decoders based on the channels on DVDs...
  5. Singh
    Singh
    Feb 9, 2004
    365
    +19
    Well if ffdshow works, then you can use it for everything :)
