Lost my recycle bin, can i get it back?
Discussion in 'Microsoft Windows' started by ScouserAndy, May 4, 2007.
  1. ScouserAndy
    ScouserAndy
    May 30, 2004
    952
    Merseyside
    +22
    Somehow the recycle bin has vanished, is there a way of getting it back?
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    Easiest way is to add it as a gadget to the sidebar
  3. Mr X
    Mr X
    Aug 8, 2006
    6,967
    3
    +2,569
    I assume your using Vista so all you need to do is go to control panel then personilsation then on the left you will see tasks and change desk top items. Within that you can choose what icons to display on your desktop.
  4. ScouserAndy
    ScouserAndy
    May 30, 2004
    952
    Merseyside
    +22
    done the trick, thanks!
