Lost "My Documents" folder from desktop
figoagogo
I have lost the My Documents folder from the desk top on XP. How to I restore it properly? Its not in the Recycle bin, currently I have a short cut but I am not 100% this is the correct way.
Kryters74
Click on start, go to the 'my documents' icon and right click, you should then have a show on desktop option, click on that and the 'my documents' folder should appear on the desktop.
Hope this helps
Nick
figoagogo
Hope this helps
Nick
will try tonight! thanks
m
Dik1985
Or...
right click anywhere on the desktop, select 'properties'
Select the 'desktop' tab
Select 'Customize Desktop' button
tick the check boxes of each item you want to show on the desktop
Hit 'OK' and 'OK' again.
Spoilt for choice!
Dik1985
Sorry, was just trying to help didn't see how old this post was.
Didn't mean to bring it back from the dead.
