lost mvp what next
Discussion in 'E-Cigarettes' started by big rd, Jul 5, 2015.
  1. big rd
    big rd
    Nov 25, 2006
    386
    28
    Reading
    +27
    I lost my mvp 2 and nautilus so I need something new can you guys recommend a replacement and and upgrade for the mvp and the nautilus.
    I have arthritis in my fingers so I will stick with replaceable coils.
    I have been happy with the old set up but it dosnt hurt to try something new I fancy the eleaf 50 or something along those lines.
    thanks
  2. Derkster
    Derkster
    Sep 21, 2006
    1,026
    Bolton
    +266
  3. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
  4. jerryq7777
    jerryq7777
    Sep 28, 2004
    4,296
    +677
  5. big rd
    big rd
    Nov 25, 2006
    386
    28
    Reading
    +27
    hi guys sorry for the late reply in the end I went for the coolfire 4 and mini nautilus I found this ok but it had a short battery charge so I got the mvp 3 pro and the isub g tank.
    wow this really is on another level I am now on the look out for another sub tank and rather than another isub is there something better I should aim for.
  6. walks
    walks
    Jan 24, 2015
    146
    Swindon
    +68
    It usually divides opinion, but if you're looking for a subtank then take a look at the Kanger Subtank Mini. Can't recommend it highly enough.
  7. owen021173
    owen021173
    Apr 5, 2007
    4,726
    scarborough
    +339
    Hi. Just come across you're post.
    How are you finding the mvp pro 3? What battery like on it?
  8. big rd
    big rd
    Nov 25, 2006
    386
    28
    Reading
    +27
    hi I find it very good I have not tried many others though battery life is good it lasts three to four days with the nautilus and about two with a kanger subtank mini this is with getting through about 30 ml of juice in the subtank in two days.
    I would highly recommend it in its price range.
  9. owen021173
    owen021173
    Apr 5, 2007
    4,726
    scarborough
    +339
    Many thanks for getting back to me[emoji3]
    I also have the mvp pro but I'm sure there's an issue with the the battery on mine as struggling to make it last a day.
    In fact it's now 6.30 and it's on charge already with the yellow led, I have use 12ml of liquid today and it needs a charge to see me through the night , not good enough for me.
    Been in to with the retailer but waiting to hear back. They've told me if its faulty they will replace it but if it's 'liquid damaged' it will be void.
    Should be interesting seeing as neither of my tanks leak
    Must also add I'm only using it at 4.0v with either the iSub g tank or the new crown tank I've just had delivered of the same retailer
  10. big rd
    big rd
    Nov 25, 2006
    386
    28
    Reading
    +27
    how long are you charging it for do you wait for the green light to go out.
    it does take a long time to charge to full .
    also have a look at the new innokin isub apex tank it beats the subtank mini and aspire triton tank hands down in my opinion and costs 23 quid on amazon
    good luck with the retailer
  11. owen021173
    owen021173
    Apr 5, 2007
    4,726
    scarborough
    +339
    I charge it overnight ,about 6 hrs, every night. Although now I have to put it on charge early evening and limit my use while it's plugged in so I can boost it to see me through the rest of the night.
    I was planning on getting another one but these battery issues are putting me off but realise it could be a duff unit.
    I used the previous itaste mvp for nearly 3 years before getting this and it holds charge (1.5days) the same as when I got them
  12. big rd
    big rd
    Nov 25, 2006
    386
    28
    Reading
    +27
    yellow means its half empty and it will last quite a while red is empty.
  13. owen021173
    owen021173
    Apr 5, 2007
    4,726
    scarborough
    +339
    Yeah mate I know that but timed it the other night from when it turned Amber to fully flat and it was just over 3 hrs with average/normal use as I had to make it last the night.
    I personally think it's gone duff on me so sending it back to Kingz of vapour for them to test it. They've been pretty good so far and have agreed to buy another one to try and deal with the faulty one when something happens.
    The word on the net and the reviews rave about it battery life so I'm willing to try on again.
    Thanks for posting your thoughts though @big rd
