Lost in the land of connectivity confusion
Discussion in 'Plasma TVs Forum' started by jesone, Jun 18, 2004.
  1. jesone
    jesone
    Jun 18, 2004
    56
    +3
    Having finally decided to buy a 42PWD6 I’d like to make sure that I cater for and specify the correct/best connectivity.
    My initial plan is:
    Connect my Sony S735D DVD component video out to component video input on Denon AVR-3802 and use the component video out to component video terminal board on the plasma.
    Connect Sky+ via a JS RGB to Plasma VGA box into embedded VGA input on the Plasma.
    PS2, Gamecube and Xbox connect into Denon S-Video input but I don’t think I can switch to use the component video out so I think I’m faced with needing a further terminal board on the plasma or some kind of switching unit.
    I'm certain there is a more elegant solution here and I would greatly appreciate any help or ideas.
