Lost a mux on blackgold dvb-t card
Discussion in 'Desktop & Laptop Computers Forum' started by Dunkwho, Apr 22, 2005.
  1. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    Its probably just affecting me ... anyone else suffering with a BG DVB-T card at the moment? I've also got a nova-t in my system for dual dvb-t recording, disabling one or the other in hardware manager has proven its only the BG card thats having a problem, the nova-t is fine. I've switched aerial feeds without improvement ... 1/2/3/4 are fine - bit odd :confused:
    Sandy heath transmitter by the way ... MCE2k5. Also - all of my scheduled recordings have decided to become un-scheduled! All the series recordings I've specified are listed ok in the recorded\scheduled\series page, but nothing's actually listed in the scheduled recordings list :(. Hmmmmmmmmm
    Duncan
  2. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    What does it mean to have lost a mux? I'm not sure what your problem is.
    I've got a SweetspotMCE which is the black gold card and is running without problems.
    However, I also lost alot of my scheluded recordings the other day, I figured out this was because Channel 4 had lost its listings for some reason! Once I added the listings back, I had to manually choose those programs again
  3. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    a mux is one RF channel's worth of programs in DVB world - it uses the same space as each individual analogue TV channel but contains a whole group "multiplexed" together. Loose 1 mux and you loose 5-10 channels in DVBland, theres only 6 muxes carrying all that DVB data (including the DVB radio stations).
