Quantcast
Question Loss of signal
LuckyLucan
After setting up my new Panasonic tx500 I occasionally lose signal on BBC 1 & BBC2 requiring me to retune all channel any suggestions could it be arial? my old tv worked perfectly from same arial
JayCee
The most likely thing is poor reception, so yes it could be your aerial.
Also, If you have any equipment connected by HDMI try temporarily unplugging the HDMI cable at both ends and check if the signals return.
HDMI cables have been known to radiate spurious RF and can knock out reception completely on some channels.
