Loss of aspect switching
Discussion in 'Plasma TVs Forum' started by steve 111, May 25, 2004.
  1. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    If I use a RGB>VGA convertor to connect Sky + to my Panny PWD6, apparantly I lose 'aspect switching'. Can someone explain what this means?
  2. Wazy
    Wazy
    The sky box sends a signal down the scart lead (pin 8 I think) which tells the tv to change from 4:3 to 16:9 etc. The vga connection on the panny unit does not allow this signal to be sent through.
    So there is 2 options. 1) Manually switch using your panny remote. or 2) get a aspect ratio switcher see the top of this forum or in the classified or offers sections to get one :)
    Personally I'd just set my screen to 16:9 and leave it at that and just manually switch over for the odd program where needed. Others though do prefer it to auto switch, but this comes at a cost.
  3. samhain
    samhain
    Apr 1, 2004
    2,779
    South West Scotland
    +129
    £100 ish for the switcher. I do prefer a sharper picture with a 4:3 image
