Loss of all sound
Discussion in 'Xbox Forums' started by CoolBreeze9, Jun 14, 2009.
  1. CoolBreeze9
    CoolBreeze9
    Dec 14, 2008
    1,318
    +75
    So I was playing some CoD and got a little bored, so I flicked from the AV channel to Sky and watched TV for a while, and when I switched back.. I wasnt getting any sound at all from the xbox. No game sound and no sound from dashboard browsing (those little pings you get while scrolling). I turned the xbox off and turned it back on, with no luck and made sure the cable was connected up properly, which it is (HDMI cable).
    Anyone know why its done this and how to fix it? :confused:
  2. Hillskill
    Hillskill
    Moderator/Games Reviewer
    Mar 10, 2005
    22,656
    Somewhere being wrong but staying strong
    +5,504
    Do you use HDMI to deliver sound to the TV ?
  3. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,845
    127.0.0.1
    +7,660
    @ Steve: See bold
  4. CoolBreeze9
    CoolBreeze9
    Dec 14, 2008
    1,318
    +75
    I think hes asking because some people use optical to output sound and the HDMI for video only. But I dont, sound is also through HDMI for me.
  5. Sniper Ash6
    Sniper Ash6
    Jun 5, 2008
    27,845
    127.0.0.1
    +7,660
    its most likely to do with the handshaking and that the TV switches audio inputs - from 360 input to tuner and then has trouble switching it back properly
    you able to try with phono or something briefly as that shouldnt have any problems and would show its to do with the HDMI properties/tv input properties
  6. CoolBreeze9
    CoolBreeze9
    Dec 14, 2008
    1,318
    +75
    Yea I have the component cable to try it. Was trying to avoid using it though because my TVs up on the wall and its hard getting my hand behing it to plug cables in. Seems totally random though, working 1 minute and not the next.
    Will give it a shot and see whats what. Cheers Ash.
  7. Hillskill
    Hillskill
    Mar 10, 2005
    22,656
    +5,504
    Just a case of trying all variables. Test different HDMI leads, different HDMI sockets on your telly. Also if you have an amp test an optical output aswell. If you are indeed using a HDMI direct to your TV for audio make sure its set to Stereo as apposed to 5.1.
  8. sdb123
    sdb123
    May 17, 2005
    18,182
    2
    Rushden, Northants
    +2,252
    This shouldn't make any difference whatsoever....
    I leave mine on 5.1 and can switch between TV sound (2-channel) and my surround headphones with no problem at all.
  9. Hillskill
    Hillskill
    Mar 10, 2005
    22,656
    +5,504
    But that only really proves that it works for you ;)
  10. virtual_boy
    virtual_boy
    May 21, 2008
    2,505
    Isle of Man
    +442
    My TV did this a while back (Samsung LE46A656), had to turn the TV off and back on again but hasn't done it since.
  11. CoolBreeze9
    CoolBreeze9
    Dec 14, 2008
    1,318
    +75
    Interesting, my TVs the LE40A656.. maybe its a Samsung thing. Annoying thing is, Ive already switched the cables to a component and didnt switch the TV off while doing it. It would have been good to test it. Although I actually prefer the picture from the component cable.
