Losing hard drive space
Discussion in 'Satellite TV, Sky TV & FreeSat' started by pauldyworth, Dec 3, 2004.
  1. pauldyworth
    pauldyworth
    Has anyone else noticed their Sky+ losing its hard drives storage capacity. I've a mk2 box and about a month ago I noticed when I added the free space % I was being shown as having, to the total amount of memory being taken by recorded programs, I was about 25% short. Having just got back from a week away, its now shrunk to under 50% in total. Anyone any ideas?
    Regards
    Pauldyworth
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Do a Planner Rebuild, it should give you back the "lost" hard drive space.
    As with all things you do it at your own risk:)
    On the remote...
    Services
    4
    Select
    The choose Option 7 and then wait.
  3. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    I have a similar problem of 50% missing memory. Will the planner rebuild lose the current recordings as, if so, the wife will go bananas?
    Cheers,
  4. BigT
    BigT
    Jun 8, 2005
    70
    11
    Fareham, Hampshire
    Same happened to me.
    Try powering the box down, from the mains.
    Leave it 5 mins and switch back on.
    Worked for me.
  5. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    Thanks - before I try - did it keep the recordings?
  6. BigT
    BigT
    Jun 8, 2005
    70
    11
    Fareham, Hampshire
    yes.
    No problems.
    Hope it works.
  7. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    I think as I'm at work at the moment that there is an option to do a rebuild without deleting the existing recordings...
    John
  8. derekn
    derekn
    Jun 8, 2004
    692
    28
    Bristol
    +37
    Thanks Guys.
    Watched the critical recordings first - ie caught up with "24".
    Then tried the "off and on" approach with only one (test) recording listed but still had only 57% free afterwards.
    Went for the option 7 planner rebuild in Services and it worked fine - even retained my recording :) .
    Cheers,
  9. dalvin
    dalvin
    Jan 7, 2005
    531
    +13
    I don't mean to sound thick or anything, but I'm having the same problem with losing hard drive space.
    I recently received the new SKY update, which amongst other things, makes the menu screens all light blue instead of dark blue!! lol.. anyway..
    just below the xx% figure, there is a thin blue line which shows you whereabouts the programs are recorded on disk. I noticed that about a quarter of this line was shaded (darker blue than rest of line) and the total percentage left was 82% -there are no recorded programs, only a few series links set up etc..
    I searched these forums, and found people have given solutions for planner rebuild etc.. by doing "services, 4, 0, 1", but I just cannot access this menu.
    I hit services, then hit 4, then hit 0 and nothing happens. It's still stuck in the "4" menu (can't remember what that is right now)..
    Is this because I have the new software update that I cannot access this menu?
    I'm still under my 12 month warranty, so I was gonna ring Sky anyway, but was just interested in why I couldn't access the menu.
    Thanks in advance.
  10. BillyTheDad
    BillyTheDad
    Apr 16, 2005
    30
    My planner keeps losing space and the only way to fix it is to do a planner rebuild. This does wipe out all previous recordings though.
    To access it press services then 4. Then you need to press 0 1 and select in quick succession. This will bring up the engineers menu and from there you can do the re-build.
  11. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    As the menu you are trying to access is hidden nothing will appear to happen when you press 4 but if you press 1 then Select in quick succession, it will take you to the relevant menu.
    John
  12. dalvin
    dalvin
    Jan 7, 2005
    531
    +13
    ahhh.. "in quick succession" was the part that i forgot to try!! hehe
    i will try it tonight..
    although, do u think it's better to ring sky seeing as i'm within my warranty? or will they just tell me to do the same thing anyway?
  13. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    No point ringing Sky at the moment as the engineer will probably do exactly the same and will charge you £65 for the privelige. I've done the rebuild a few times and it's always given me the space back.
    John
  14. dalvin
    dalvin
    Jan 7, 2005
    531
    +13
    why would i get charged £65? I'm still within my 12 month warranty period
  15. johndon
    johndon
    Feb 3, 2002
    1,971
    63
    +108
    Sorry, didn't spot that.
    John
