Losing Channel 3
Carder1Y
Yesterday evening I was watching channel 4 on my 6 months old Samsung 42” tv and decided to have a look at Ch3. The picture appeared for about 10 seconds and then disappeared. Have tried lots of times since then but the same thing happens: picture appears and then disappears. No other channel is affected, only Ch3. If I swap over to Ch103 there is no problem and I can watch the programmes there. Advice would be much appreciated.
JayCee
Probably a signal problem but my advice is just to forget about CH3 and continue watching 103 instead.
CH103 is the HD version of CH3 and should give you a sharper picture.
Carder1Y
Thanks for the quick and very helpful reply. The difference is not only sharper but better in all respects. Will now try out the other channels too.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
