lord of the rings anamorphic?
Discussion in 'Movie Forum' started by keyser, Aug 6, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    The widesceen version of lord of the rings is anamorphic isn´t it, doesn´t that mean it should fill up my widescreen screen, or am I getting things wrong again. Is the pal version any different in that matter than the ntsc one?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    The film is presented in a slightly wider aspect ration than a widescreen TV so there will still be black bars on the top and bottom of the screen
  3. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    Don't you get green borders if it is anamorphic?
  4. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    :D :D :D
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,565
    Somewhere in South Yorkshire
    +6,083
    It WILL fill your screen. It's just that WHAT it fills your screen with, is a widescreen film plus some black padding top and bottom. It is the only way they can make a DVD so as to get a 2.35:1 film to fit onto a 1.77:1 screen.
  6. European
    European
    ...erm... "anamorphic" has nowt to do with the aspect ratio of the display - it refers to the way a film is transferred to disc...
    ...since 16:9 works out to 1.7777777 (1.78:1 for short) and the widescreen version of LOTR has an AR of 2.35:1, there will still be (narrow, horizontal) black bars on a 16:9 screen, regardless of whether the film has been transferred 'letterboxed' or 'anamorphically'...
    ...theoretically, 1.85:1 and 1.66:1 films shown on 16:9 displays will also have (very narrow) black bars (horizontal ones for 1.85:1, respectively vertical ones to the left and right of the image for 1.66:1), again regardles of whether they are letterboxed or anamorphic... in practice, however due to overscan such films as often as not will 'fill' a 16:9 display...
    ...most widescreen TVs and some DVD players will let you 'zoom' the picture so it will become screen-filling... doing so will inevitably make the picture look worse, and/or distorted...
    ...only program material that has a 'native' AR of 1.78:1 will actually 'fill' the 1.78:1 ( = 16:9 ) screen of a 16:9 TV or display...
    . . . :eek: . . .
  7. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    It does in as much as a non anamorphic widescreen DVD is a widescreen image presented within a 4:3 shape, wheras an anamorphic DVD is a widescreen image presented within a 16:9 shape. :)
  8. European
    European
    ...alright... alright... me wrong, you right...
    ...leaves room with bowed head, mumbling something into his scraggly beard...
    . . . :D . . .
