Loosing one Color on from Sky on PIO 433
Discussion in 'Plasma TVs' started by rsvman, Dec 15, 2003.
  1. rsvman
    rsvman
    Oct 28, 2002
    140
    16
    +3
    Not sure if it should be in this paret of the forum or sky/receiver forums..
    Anyway..
    Have Digital Sky connected scart to rgb converter component into denon 3802 upto plasma via component.
    every now and then i tend to loose one color, ie the picture goes more green..
    To clear this i have to turn of the denon and then turn it back on again..
    Has anybody ever come across this ??
    I'm try to figure out if the problem lies with the cabling, sky box, denon or rgb converter ..
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,040
    +1,111
    Sounds like a cabling issue.
    See if the scart into the convertor is a bit loose : sounds like the red pin is intermittently losing contact.
  3. nealgs
    nealgs
    Also try it direct to plasma without the 3802 in the equation. We have similar setup except Yammy RXV1000 doing the video switching, but not had any colour issues.
    Gary
