I'm Sorry, Im pretty new at this.
But for the past 4 months, i'm loosing channels.. Yes ur right, i live in an apartment block & have a communal aerial, few people are facing the similar problems. But not all.
The building manager had called in an AV engineer & had the aerial chked. According to him after the switchover it works fine.
But i only get the BBC channels..
This is quite distressing, I figure after a month I might loose all my channels :'(
Thanks for your advice. My TV uses a Scart Cable connection from my freeview-box.
Since the past 3-months, there are no occasions when i recieved all the channels together.
I dont have a substitue flycable, but my bbc channels are very clear. I dont know if that helps. But if you suggest I try another cable, i'll do so.![]()
