loosing colour from sky
Discussion in 'Sky Digital TV Forum' started by rsvman, Dec 15, 2003.
  1. rsvman
    rsvman
    Oct 28, 2002
    140
    16
    +3
    Not sure if it should be in this part of the forum or plasma/receiver forums..
    Anyway..
    Have Digital Sky connected scart to rgb converter component into denon 3802 upto plasma via component.
    every now and then i tend to loose one color, ie the picture goes more green..
    To clear this i have to turn of the denon and then turn it back on again..
    Has anybody ever come across this ??
    I'm try to figure out if the problem lies with the cabling, sky box, denon or rgb converter ..
  2. HMHB
    HMHB
    Nov 11, 2001
    26,848
    Nottinghamshire
    +5,624
    My picture goes to black and white occasionally on Paramount
