Loosing color from sky on denon 3802
Discussion in 'AV Receivers & Amplifiers' started by rsvman, Dec 15, 2003.
Tags:
  1. rsvman
    rsvman
    Oct 28, 2002
    140
    16
    +3
    Not sure if it should be in this part of the forum or sky/plasma forums..
    Anyway..
    Have Digital Sky connected scart to rgb converter component into denon 3802 upto plasma via component.
    every now and then i tend to loose one color, ie the picture goes more green..
    To clear this i have to turn of the denon and then turn it back on again..
    Has anybody ever come across this ??
    I'm try to figure out if the problem lies with the cabling, sky box, denon or rgb converter ..
  2. Jase
    Jase
    Mar 16, 2001
    9,530
    UK
    +930
    Best thing is to bypass the Denon and connect directly to the plasma and see what happens. If it still does it then at least you can eliminate the Denon as being the cause (unless it's the cabling from the Denon to plasma).
