Loose end on a Canon EF-S 18-55mm f/3.5-5.6 USM Lens
Discussion in 'Photography Forums' started by mark.carline, Feb 2, 2009.
  1. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    I have just picked up a 2nd hand canon lens (as per title) and I *think* the end of the lens is loose.
    If anyone else has one of these lenses could they let me know if its slightly loose ?
    I'm not sure if its just me being paranoid. :eek:
    Thanks!
    Mark
  2. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
  3. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    they all have a slight amount of play in them , how loose is yours ??? :)
  4. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    maybe 1mm or so
  5. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    sounds pretty much the same as mine and my 55-250 IS , been assured it is normal by my local independant supplier , and on here :)
  6. mark.carline
    mark.carline
    Jan 15, 2004
    2,133
    Chester, Cheshire
    +121
    Thanks!
    It does seem to be normal as I took it to a local camera shop in Chester and they said its totally normal. They showed me a brand new one thats never been out of its box and that was loose also.
    Surprising as my other Tamron is nice and tight.
  7. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    the explanation i got was so that the motor does not need to struggle to turn a tight lens , my opinion , it is a price point thing so the lenses can be built down to a price , might be wrong on that though :eek: :rotfl:
  8. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    Just thought I'd bring this thread up, since I have just received the 55-250 that paul's on about in this thread, and was a bit worried, as to me it seems very loose. My 18-55 is hardly moves in comparison, but does have a little bit of play... So I was a little bit worried... Although if paul says he took it to his local independant, then I guess all's ok. Just wonder what other's opinions are?
    Also, I noticed that the motor is a lot noisier than on my 18-55mm. I was shocked to hear the noise of it so loud. Compared it to my 18-55, and that is a whisper. Any other's opinions on the motor noise? Could it be that it's so noisy because of the looser end?
  9. jradley
    jradley
    Jan 16, 2004
    895
    43
    +215
    Do you mean the IS motor noise is louder ? I thought my 55-250 was broke too when I got it but I subsequently found out that is a common thought with this lens and it's nothing to worry about. The focus motor is perhaps a little noisier too.
    From recollection there is more play in the barrel too than on my 18-55, so that is probably ok too.
    Good luck,
    John
  10. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    seems as though it is a common thing , i have just got the 70-300 IS and the IS is noisy in a quiet room :eek: , takes sharp pictures though , and that suits me :thumbsup:
  11. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    Cheers, at least I know the is noise factor is no prob then :)
    What about the play on your 18-55 compared to the 55-250 John? Is this about the same, or does your 18-55 have less play than the 55-250? Cheers
  12. jradley
    jradley
    Jan 16, 2004
    895
    43
    +215
    I stand corrected - the 18-55 actually has *more* play in it than the 55-250, especially given that it doesn't extend as far so I would have excpected it to perhaps be more snug. In comparison, the 18-55 feels like it's about to fall apart, whereas the 55-250 just feels a bit loose :D
    The IS on the 55-250 is definitely more noisy though - I was right on that one.
    John
  13. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    lol, just goes to show what the quality control on these things is like!!! lol.
    Gonna give the 55-250 a good test tomorrow hopefully... :)
  14. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    have fun :thumbsup:
  15. lovelldr
    lovelldr
    Jul 19, 2006
    2,287
    63
    East Midlands
    +148
    Cheers, will do :)
    BTW, posted your sd cards yest, forgot to tell you. Missed last post though. But should be with you next week :)
  16. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    cheers :thumbsup:
