Looking to upgrade from lg65uf8500
Discussion in 'What Is The Best TV For You?' started by Kyle Braunlich, Aug 25, 2018.
  1. Kyle Braunlich
    Kyle Braunlich
    Aug 25, 2018
    4
    USA
    I recently got a 4k Blu-ray player and am looking to get use of the hdr. I was wondering if there is a tv out there that anyone could recommend (if possible oled or similar technology) that is at $1000 or less.
    Thanks for any help!
    -Kyle Braunlich
    EDIT - I found a TCL TV for $660 and not sure if it would be a downgrade or not based on price, even though I bought my tv a while ago. Here's the link
    TCL 65" Inch 4K ULTRA HD 2160p Smart Roku HDR 120Hz LED TV 65S403 - NEW 846042008242 | eBay
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,215
    +4,407
    Do you need good viewing angles like with your LG?
    If so, you need to look at OLEDs.
    The $600 mark is not going to be an upgrade at all.
    If you look at TVs with VA panels instead you are looking at a minimum of $1500 to have good HDR at 65".
