Looking to replace wired thermostat with Hive
Discussion in 'Renewable Energy & Energy Saving' started by Shawkat, Dec 29, 2016.
Tags:
  1. Shawkat
    Shawkat
    Mar 28, 2005
    324
    +3
    Hi everyone,
    Im looking at getting my old central heating system replaced soon. It has a wired dial type thermostat in the hallway. The actual boiler is located in an extension on the side of the house and this is where the new boiler will also go. I am looking at getting one of those HIVE wireless thermostat/programmer controls fitted to the new boiler. Wireless signals do not pas through the thick outside walls to the extension.
    Therefore, i am wondering how i should position the HIVE system? Is it possible to have the receiver part of the HIVE wired to the existing hallway location and then have the wireless programmer positioned elsewhere in the house? or does the receiver have to be positioned clsoe to the actual boiler which will likely result in the programmer not being able to communicate with the receiver.
    Hope the question makes sense - thank you in advance :)
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,840
    7
    2
    167
    Birmingham, UK
    +10,800
    Do you need to worry about it? Maybe let the British Gas engineer who comes to fit Hive worry about it. I ordered Hive on an Amazon sale and the guy just came and did it. A few weeks later I received a booster plug because apparently our hallway controller was losing connection to the boiler room unit.
    I was blissfully unaware.
  3. Shawkat
    Shawkat
    Mar 28, 2005
    324
    +3
    Thanks for the reply. I was going to ask the boiler engineers (who are not British Gas) to fit the device when installing the new boiler...
