Looking to replace my speakers . Any ideas?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by DonMaico, Sep 23, 2004.
  1. DonMaico
    DonMaico
    Must be sensitive and not demand too much current as I use valve amplification.. My Heybrook Hb1s are getting a bit long in the tooth being about 20 years sold.There is a French company called Triangle who make nice looking speakers which are apparently ideally suited to valves.Either the Titan or Comette would suit my budget.Anyone have any thoughts? My listening room is small so they cant be too fussy about placement. :)
  2. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
    Don, Castle loudspeakers are an easy drive reasonably sensitve too, they also have a sonic flavour that would IMHO appeal to those orientated towards a “valve” sound. Well worth consideration at all price ranges.
    http://www.castle.uk.com/pages/classic.htm
  3. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    A bit pricey (start around £1700), but Living Voice might be worth a look. There's even a pair of Auditorium Avatars on the bay at the moment!
    DT
  4. DonMaico
    DonMaico
    Castle Durhams !Yes I remember them ,look good too. dont want to get into £1000 plus territory as the men in white coats might appear at my door.
  5. WhyAyeMan
    WhyAyeMan
    Jul 4, 2002
    3,072
    Newcastle
    +292
    I'd consider trying some Rega speakers, as they tend to be quite easy to drive and not too fussy about placement, although I speak largely for the "Ela" model with this
  6. DonMaico
    DonMaico
    When you say bay do you mean ebay? :)
  7. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    yes Don, this forum has clever software that blocks things like swear words etc, so I wasn't sure if it would allow "eBay" - hence "on the bay".
    DT
  8. DonMaico
    DonMaico
  9. DonMaico
    DonMaico
    those avatars have already hit the £700 mark and there is four days to go.Think i'll give them a miss.
  10. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
  11. DonMaico
    DonMaico
    thanks for that link knightshade, I forgot about it :thumbsup:
  12. recruit
    recruit
    Hi DonMaico,
    What about Proac speakers they are quite easy to drive and i have had my Response D15's for about a year now and they sound superb i can imagine they would sound even better with valve amplification.
    John :)
  13. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Have you considered the Tannoy Sensys DC1 and DC2s or even the Eyris range. They are really easy to drive and sound great.
  14. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
    Hi Don
    Many moons ago I changed my Heybrook HB2's for a pair of ProAc Studio 1 Mk2's on Target R2 stands. I was using a pretty modest integrated at the time and they worked well. Tremendous midrange, very nice topend, the only weakness was a lack of deep bass, later I added a Rel Sub and better amps, each time the ProAcs handled the upgrade and only recently have I changed to MA, still have the ProAcs though :).
    Their replacement the Studio 100 and it's bigger brother the 125 would be worth an audition.
    http://www.proac-loudspeakers.com/studio100.php
    Gus
  15. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    I'll vouch for the Tannoy Eyris range. Had a pair of Eyris 1's a few years ago. Very nice neutral speaker. A bit odd to look at but very well built.
  16. DonMaico
    DonMaico
    Just missed out on apair of Celef monitors that went for £82 on the ebay . Grrr!
  17. DonMaico
    DonMaico
    Thinking about a pair of Kef QW 4 s which are on the bay now (91db and 8 ohms)
  18. braehead
    braehead
    I've just auditioned and reserved the Tannoy Eyris 2 front speakers and matching centre speaker :thumbsup: . Tested them against Monitor Audio S6's and matching centre. The biggest difference came from swapping the centre for the Tannoy - massive improvement. The fronts didn't work as well with the sub for music but are great without - need to save for a better sub (it was a Velodyne one at the £300 mark, so a lot less than the Tannoys - worked well with the MA's though). I thought long and hard about the Warfdale Pacific Evolutions. They looked and sounded really good (pretty big though) but I'm getting a good deal on the Tannoys and that swung the decision in their favour.
  19. braehead
    braehead
    Changed my mind on the Tannoys and done a deal on a Mission 782SE full 5.1 set up. The centre is not as sparkling as the Tannoy but the whole thing together sounded better and the fronts were better (to my ears) for music. At the end of the day the Tannoy centre turnded out to be too large to fit into my rack because of the raised tweeter so I was kinda stuffed there anyway!!
