Looking to buy two 500gb external Drives to RAID
Discussion in 'Computer Components' started by devs, Sep 11, 2007.
  1. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    Just wondering if anyone has any recommendations? Must not cost the earth ;)
    Many Thanks,
    Devs.
  2. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    hmm not sure how you get two external drives to work in a RAID, if you go by USB it'll be slower (what type of raid)
    Or you could get a dual bay NAS, slower but built in RAID.
  3. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    Hiya mate and thanks for the reply, I'm not well up on this so may well be talking out of my hat...
    I plan to use these drives on a Mac and just thought it would be as simple as attaching both the external drives and selecting them both and setting as RAID?
    I'm currently using a WD MyBook 500GB yet would like to back this up also so thought going RAID would be a good fool proof option as I'd hate for the drive to fail.
    Cheers :smashin:
  4. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Not so much RAID as a duplicated disk for backup then - bear in mind that you'll only get half the amount of space at the end either way.
  5. devs
    devs
    Mar 23, 2004
    1,621
    38
    +24
    Yeah thats fine a total of 500gb is fine for my needs. I thought that RAID was a system for copying to two separate drives at once?
    Anyone have any drive recommendations?
  6. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    You could get 2 x branded external USB drivces (Maxtor/Iomega etc), and use the backup software that comes with them to do a full backup from one drive to the other.
  7. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Or you could get an external enclosure that supports RAID 1 and put two drives in it - a better solution really but probably more £££
