Looking to buy this build, recommendations?
Discussion in 'PC Gaming & Rigs' started by etylerb11, Apr 20, 2016.
  1. etylerb11
    etylerb11
    Apr 20, 2016
    2
    Texas
  2. jassco
    jassco
    Feb 10, 2009
    5,967
    +2,867
  3. Fxz123
    Fxz123
    Mar 23, 2015
    UK
    Unless you already have pre-skylake parts I would definitely go Skylake for the DDR4 capability.
  4. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    The setup looks fine, id sack off the DVD drive and pickup a 3rd party cooler (evo 212 or Seidon 120v are good for the money)
    Seeing as your buying all new parts, Skylake might be a good way to go, the prices of Haswell and Skylake are near enough the same these days assuming DDR4 is going to be around for a while, you'll have parts you can use on your next build. If you stick with Haswell, the i5-4690 is a popular choice.
    Dont forget to factor in cost for any spares as well, stuff like cables, fans and cpu coolers that kind of thing.. all adds up.
