Looking to buy a Plasma
Discussion in 'Plasma TVs Forum' started by Abbs985uk, Apr 19, 2005.
  1. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    Looking to buy a plasma, price isnt too much of an issue but would like something in a 32 inch size or max 37. However, I havent come across any (in that size) that have HDMI and the pioneer 43 inch is probably too big for my room.
    Would really like to have a HD Ready Plasma or even LCD but dont want anything too big.
    Any suggestions?
    If not guess the Sony 32 inch ones are a possibility with component HD source inputs...
  2. WhiteNoiseMaker
    WhiteNoiseMaker
    Mar 4, 2005
    42
    +4
    Wait another month for the Panasonic VIERA TH-37PV500B! :clap:
  3. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    ive read somewhere that the TH37PW is HDTV compatible and this can also have a HDMI card fitted. Is this correct as there are some cheap panels going and it seems like a good deal. Any views?
  4. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,716
    137
    Middle Earth
    +616
    The TH37PW is not UK HDTV compatible via HDMI/DVI. It cannot display 720p lines at the PAL frequency of 50Hz.
    You can get it to work [email protected] via component, but this connection method may or may not be any good for SKY or HD DVD. You can get it to display [email protected] with an external scaler to convert at around £1000 extra, but the results are not always thought to be great.
    Best advice is wait a month for the PV500 range.
  5. theios
    theios
    isn't it 500E?
  6. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,716
    137
    Middle Earth
    +616
    I think it's B in the UK, but in Belgium it may be E.
    Maybe B for Briton and E for Europe!?!?
