Looking To Buy A 50" Plasma-Your Suggestions Please
Discussion in 'Plasma TVs Forum' started by a4lloxo, May 3, 2007.
  1. a4lloxo
    a4lloxo
    May 31, 2005
    1,177
    the city or town where you live
    +127
    Hello,ill be looking for a 50" plasma in a couple of months time.ive had a look at a few,but am unsure as what would be the best for me.I will be investing in some hi def hardware so id really like a 1080p ready screen.my budget is around £4000.any suggestions would be greatly appreciated.thanks:thumbsup:
  2. yoclick
    yoclick
    Apr 2, 2007
    147
  3. Piers
    Piers
    Dec 11, 2002
    1,995
    Cheshire
    +230
    I am wondering where you have looked at potential screens and what they showed you?
    £4,000 gets you into the league of the "Full HD" screens. Do you want / need one and will it be better than a really good "HD Ready" screen may be the question.
    If you sit very close to your screen then the Full HD may well be the answer. If you don't, you won't see the difference.
    If so, save on the screen, get the cheaper option properly set up, sit back and enjoy.
  4. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    As Piers said, Full HD from Panny with their commercial PF9, which may be replaced soon if like the PH9 being replaced in June with the PH10.
    Then there's the regular HD from Fujitsu - considered the absolute dogs danglies.
    Couple that with Pioneer's new 8G panels coming soon, Full and regular HD versions of 508 - is the hype warranted? Soon enough we'll be told by those attending the Italian soiree on the 8th.
    And by no means least, Panny consumer PZ700 unit.
    So if time is on your side, then you're going to have a wonderful headache (or four) trying out those beauties ranging from £2.2K (ish) - £3.5K (ish).
    Get Piers to ISF calibrate it for you when you get it, and sit back and enjoy.
  5. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,704
    Woking
    +237
