Looking to but a Pioneer PDP-436XDE
Discussion in 'Plasma TVs Forum' started by TankEngine, Mar 27, 2006.
  1. TankEngine
    TankEngine
    Mar 27, 2006
    41
    We're looking at making the big jump to a HD TV. I've been searching and I have come to the conclusion that the Pioneer PDP-436XDE is the one for us. Is this a good HD plasma to go for??
    Any other recommendations?
  2. Bacus
    Bacus
    Dec 30, 2004
    8,995
    Close to the sea
    +2,925
    I think it the bast to go for !!! if you are going to be using it as a telly then the XDE is the beast to have !! I have had mine for about 5 weeks now and the picture is stunning and the sexy look of the plasma screen is great !! I got the 43"xde after having a HiDef 50" DLP samsung and thought i would find it had to beat for PQ, but the pioneer blows the DLP out of the water, and if you feed this screen with a HIDEF feed it will soak it up, display it and then all you have to do is bend down to pick your chin up off the floor !!!! :D :cool: :rotfl:
  3. alistaln
    alistaln
    Feb 21, 2006
    324
    46
    Reading
    +181
    And when you do (which you should!) then check out the FAQ here for loads of useful stuff.
