Looking for Yamaha A760 with voltage regulator (110/220v)
Discussion in 'AV Receivers & Amplifiers' started by Hansaplastique, Mar 27, 2017.
Tags:
  1. Hansaplastique
    Hansaplastique
    Apr 7, 2015
    2
    4
    USA
    I apologize if this is not the right place to ask ...
    I am looking for a Yamaha A760 (or if affordable A860) with the voltage regulator so I can select 110V/60Hz or 220V/50Hz input.
    According to Yamaha the "generic" model has this, but the US version does not.
    The main reason why I looking for this, is that I currently live in the US but might be moving to Europe in the next few years (work related).
  2. ashenfie
    ashenfie
    Jul 31, 2008
    1,827
    116
    Northampton
    +528
    AV receivers are often vary in features from US to UK. So some care would be need when selecting a model one and above voltage
