Looking for the impossible?
Discussion in 'Computer Peripherals & Consumables' started by andru, Sep 21, 2007.
  1. andru
    andru
    Aug 26, 2002
    317
    Mid Glamorgan
    +12
    I am looking to replace my old epson R200 printer with a allinone printer.
    I need it have have the following
    1. Good quality photo printing
    2. Scanner
    3. Fax
    4. Print directly onto CD/DVD
    5. Ethernet connection.
    6. Cheap replacement ink
    7. Copier.
    I have looked and read reviews on many,they have most things on my list all except the print to CD/DVD. If i find one with print to CD it does not then have the fax!
    Is there one out there under about £150 that will have all thet i need.
  2. andru
    andru
    Aug 26, 2002
    317
    Mid Glamorgan
    +12
    With looking at all the views and yet no responce,i take it i am at the moment looking for the impossible all in one.:(
    I gues the quest go on.
    Ta
  3. Caralfa
    Caralfa
    Yup !! You sure are at the price you want to pay. You can only get a decent printer which will print out quality prints for that. As for a decent scanner, fax etc. etc as well. An impossible search. unless someone takes pity on you and gives you one :eek:
