Cyrus might be nice, but I don't think you can get those for £800, probably closer to £1100.
Closer to your stated budget, the
Yamaha AS801 Integrated Amp with DAC is currently on sale
reduced to £699 from the previous £799 -
Peter Tyson - Yamaha A-S801 Integrated Amplifier
Here are the full specs on the Amp -
Yamaha-UK/IE - A-S801 - Overview
- USB DAC function supports 2.8MHz/5.6MHz DSD native resolution and PCM 384kHz/32*bit reproduction
- * Windows support. Mac support is 24-bit.
- High efficiency ESS 32bit DAC (ES9010K2M)
- Digital signal indicator shows DSD and PCM playback formats and sampling frequencies
- 160W x 2 (max), 100W x 2 (RMS) high power output
- 1xOptical, 1xCoaxial, 1xUSB-PC
There are plenty of great amps out there, but do they fall in the stated price range, and have the necessary features?
Yamaha are High-Value as always, and with the £100 discount, that makes the
Yamaha AS801 very attractive, and it has all the features you specifically asked for, with the exception of Bluetooth, but Yamaha does make a low cost
Bluetooth Receiver.
Yamaha YBA11 Bluetooth Wireless Audio Receiver - Superfi
However, in general,
Bluetooth Receivers can be had for about £50. You should find dozens of them on
Amazon.
Amazon.co.uk: Bluetooth Receiver
Also, keep mind if you buy a separate stand alone DAC, plan on spending between £200 and £500, or more for just the DAC.
Just a thought.
Steve/bluewizard
