Looking for Specfic WallMount
Discussion in 'Home Cinema Buying & Building' started by Lego, Jun 11, 2005.
  1. Lego
    Lego
    Just picked up my LG 26" LCD this week, but i'm having trouble finding an affordable wall mount for it.
    I want to be able to have the screen flush (or as flush as i can get it) to the wall, but the also be able to have it @ 90 degrees (or so) to the wall. (Sort of like opening a cupboard door.
    I've found a few wall mounts but they all seem to be in the £200+ region, just wondered if anyone knew if there was anything out there cheaper for my needs, or if i'm going ot have to bite the bullet and pay the money.
    Thanks in advance
  2. msg
    msg
    May 20, 2005
    421
    Darlington
    +14
    see http://www.digiuk.com/sectionlist.asp?c=1095157&s=&sm=&guid=&id=134
  3. blossom
    blossom
    Feb 15, 2004
    1,270
    41
    Solihull
    +15
    I have one of these on my Sharp 26"GA4E.
    There are others less expensive that do the same job though. Just do some searches and you should find what you are looking for.
    Paul
