bouncer
A few months ago my downstairs neighbour had an issue with there pipes backing up, Since it has been sorted out I've started to have a different issue, After the toilet has been flushed a few times, you can start to hear a "glug glug" coming from the bath plug hole, a while later there is a smell in the bathroom, If I run the water in the bath for a few seconds, That is enough to stop the smell, Untill the toilet is flushed again,
There is not alot of elevation for drainage of the bath, Im wondering if when flushed its causing a vaccum pulling the water out of the baths U bend?
Basically, Ideas on the issue and suggestions on a solution?
