Looking for small PIR/Beam sensor suitable for switching stair LED's
onelife2000
I am doing an install of LED strips along a glass balustrade. The strips will be hidden inside the handrails facing down.
I am looking for a timed Switch capable of the load (72 watts)
I have seen and am thinking about the Green-i sensors but ideally I want something that only triggers as you break the beam - I imagine they have pretty wide angle - an the problem of where to place them
Also I want to link 2 - at the top and bottom to switch the LED's
Anyone got any ideas?
Linx08
is there carpet on the stairs?
if so may have a suggestion for you.
Linx
