Looking for "Slim" A/V
Discussion in 'AV Receivers & Amplifiers' started by KaTXi, Apr 16, 2003.
  1. KaTXi
    KaTXi
    Apr 16, 2003
    11
    Hi all.
    I'm looking for a slim (less than 14 CM) A/V receiver with at least 4 Digital (2 / 2) In, DTS / DD / Prologic II and less than 600 Euros / 400 Pounds.
    I've seen 2 that fits my specifications but one is taller (Yamaha 630) and the other is way expensive (NAD T752).
    Any advice?
  2. michaelab
    michaelab
    May 20, 2002
    528
    Lisbon
    +10
    See here.
    See that button on the top left of the page with "search" written on it? Guess what - it lets you search the forum to see if your question has already been asked :lesson:
    Michael.
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Welcome to the forum KaTXi.
    michaelab, give the lad a chance :)
  4. wookie
    wookie
    Celestion Make a receiver and progressive scan dvd player that are both slimline.
    Both DVD and amp together are about the same size as a single AV amp.
    WWW.CELESTION.COM FOR MORE INFO
  5. Jimmysil
    Jimmysil
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    14cm or 140 mm is not that thin the panny SAXR10 is 52mm my SADX950 which is pretty full size is 155mm so you dont need to go Super slim just not huge!!!!! So there should be a lot of choice
    EG
    Specifications for the DENON AVR1603
    Power Output 5x 80W (8 ohms, 20Hz-20kHz, 0.08% THD)
    Frequency Response 10Hz - 100Hz (+1, -3 dB)
    Signal to Noise Ratio 98dB
    Tone controls Treble: ±12 dB at 10 kHz
    Bass: ±12 dB at 100 Hz
    Power Supply AC 230V, 50 Hz
    Input sensitivity/Impedance 200 mV/47 kohms
    Dimensions Width 434mm
    Height 147mm:D :D :D
    Depth 417mm
    Weight 10.4 kg
    Might be a squeeze but look at smaller full size amps
