NewToyForXmas
I've currently got a Panasonic 42PWD8 Panel. The only feed into this is from an Onkyo SR503E, via a Van Damme 3RCA to VGA cable. Into the Onkyo, I have Sky+, via a JS Tech RGB to Component (YUV) converter. I also have a Panasonic E500 hard-drive DVD and a Wii, both connected via component.
The problem I have run into is a desire to bring a PS3 into the equation, but I have run out of Component inputs. And I also see Sky HD being involved soon. I also have a slight annoyance with my current Amp in that as I only have Component out so can only have Component in. ie. it would be nice if the Amp could route / convert so that one input could be output via a different means. So it seems like a good opportunity to replace my AV Amp and switch to HDMI for some / all of the connections. The panel will be replaced soon but would be nice if I could do this in stages. So I guess I would be looking at HDMI inputs for the PS3 and Wii. Component via the JS Tech for the time being for Sky+, but HDMI when I move to Sky HD. Existing DVD player does not have HDMI so that will need to stay Component. So I need minimum 3 HMDI inputs, 1 Component and the option of output'ing by Component for now, moving to HDMI when I upgrade the panel. I've been really pleased with my Onkyo, just hitting some connectivity issues. Any ideas of potential models?
