Looking for region free hack for Yamaha DRX-E730
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by roland, Jun 17, 2009.
  1. roland
    roland
    Jun 17, 2009
    5
    Hi there,
    Does anyone know how to make the Yamaha DRX-E730 region free?
    It is a small PianoCraft style dvd-receiver-amp-tuner. The hack that I found in this forum for the E700 does not work, unfortunately.
    I hope someone here may be able to advise! :lease:
    Thanks in advance, Roland
  2. roland
    roland
    Jun 17, 2009
    5
    It's region free now!
    The firmware was adapted for me and I can now easily switch from the original region (2) to region free (0).
  3. roland
    roland
    Jun 17, 2009
    5
    Take a look at this thread: http://forum.pioneerdivx.net/viewtopic.php?p=15534#15534
    Just download the CD ISO (S8CA1246_patched_CD_ISO.zip) from this website, burn the image with your favourite burning program, put the disc in the tray, and follow the on screen instructions (press PLAY when you are asked, remove the disc from the tray when it opens).
    After that you have a "multiregion switch": to change to region 0, hold ENTER until player restarts; to change back to original region, hold CLEAR until player restarts. The OSD of the player nicely reports "Region 0" after doing this.
    You can check the region by entering the setup menu:
    Press the “SETUP” key on the remote control.
    The SETUP menu is displayed on the TV monitor.
    Move the cursor to [Initial Settings] by pressing the “DOWN” key on the remote control and press the “ENTER” key
    Move the cursor to [Options] by pressing the “DOWN” key on the remote control repeatedly and press the “ON SCREEN” key.
    The region is displayed now.
  4. Hkan
    Hkan
    Cool :smashin:
  5. Riton
    Riton
    Sep 1, 2009
    3
    Hi there, I didn't find the patch on the pioneerfaq website.
    May I ask you if someone of you could send me the link for the patch ?
    Thanks in advance.
  6. roland
    roland
    Jun 17, 2009
    5
    It is not the pioneerfaq website but the http://forum.pioneerdivx.net/ forum with the link that I posted. You have to register at the forum first, after that you can access the download links!
  7. Riton
    Riton
    Sep 1, 2009
    3
    Hi Roland,
    thanks it works. I did the upgrade and am very happy.
    Thanks again.
  8. roland
    roland
    Jun 17, 2009
    5
    You are welcome, most thanks should go to the guy that adapted the firmware, however :)
    I am happy it did not call your player :)
    What was the original region of your player? Mine was region 2.
  9. Riton
    Riton
    Sep 1, 2009
    3
    Mine was also region 2.
    Yes you're right regarding the guy which did the patch.
    Without him nothing could be done :clap:
