Looking for quality 240v to 110v Stepdown converter for DVD player.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jackass, Jan 31, 2003.
  1. Jackass
    Jackass
    Jan 9, 2003
    3,106
    +614
    Any suggestions anyone?
    Steve.
  2. smallman28
    smallman28
    Maplins USED to do one,dont know if they still do now.
    It was basically a plug in adaptor about the size of a AA battery charger.
    Plug the unit in then plug the 2 pin plug into the top of that.
    I had one with the first dvd player I had and it was only cheap but lasted for years.
  3. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Just make sure you get one with sufficient wattage or Va rating. Your DVD player will probably run at around 30W, maybe less. It's a good idea to go at least 10W over to prevent overheating etc. You should be able to pick up a 50W Stepdown from Maplin as mentioned above. Even try Argos :).
  4. ferris57
    ferris57
    Jan 18, 2003
    869
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    If you are in London, plenty of shops in TCR sell them.
    StooMonster
  6. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,183
    London
    +399
  7. Jackass
    Jackass
    Jan 9, 2003
    3,106
    +614
