Looking for prog scan crt Tv anyhelp !!!
Discussion in 'Televisions' started by zad, Jan 3, 2003.
  1. zad
    zad
    Jan 3, 2003
    1,327
    63
    Wigan
    +112
    im looking for a crt tv that does progressive scan 32"+ but i have limited space and will be sat on a built in unit,any pointers on which to look at would be appreciated
    thnx
    ps ive looked for ages now but most of the uk sites dont say if they do or dont do prog scan :/
  2. Martin Gibson
    Martin Gibson
    The toshiba range seems to be popular
    Look for component inputs & progressive scan capabilities.
    i.e 32ZD26P, 32ZT29P (+28 & 36 inch versions)
    Bit expensive though so have a good look round.
    Search for 32ZD26P in this forum for more info on prices.
    I believe that Hitachi and Panasonic also do progressive scan TV's - might be worth checking their home sites.
    www.techtronics.com is quite good for giving specifications.
    good luck..
  3. fuzzy
    fuzzy
    Sep 8, 2002
    40
    panny tx32 ph40, pal and ntsc prog scan..some like it some dont. I like mine:D
