Looking for new front speaker options to compliment existing rears and centre
Discussion in 'Home Cinema Speakers' started by AmigaHarrison, Sep 7, 2012.
  1. AmigaHarrison
    AmigaHarrison
    Aug 9, 2011
    I've currently got an all Eltax setup purchased some years ago. I'm very happy with it, but my wife hates the large front floor standing speakers. I'm therefore looking at options to replace the floorstanding speakers with smaller wall mounted ones.
    My current setup is:
    Eltax Symphony 8.2 floorstanding fronts
    Eltax Symphony Centre
    Eltax HT-2 Bipolar rears.
    Wharfedale SW-8 Active Sub.
    Amp is a Sony STR-DH820
    Room is about 4M x 3M so not huge.
    Are there any wall mounted fronts I could replace the 8.2's with that would work well with my existing Centre and Rears?
    I quite like the B&W M-1s. Would they work well? Anything cheaper?
    I'm also considering replacing the Sub. Is there a smaller active sub that would work nicely? Especially is I replace the fronts I will miss the nice bass from the floorstanders, so would need a sub to fill in some of the bass lost.
