Looking for multi-region bluray player
twistedtory
Would sincerely appreciate any suggestions, prefer factory build multi-region rather than hacking, as the hacks for my last one did not work and i'm not the most patient of people :rolleyes: Thanks!
Krank
As far as I know, nobody does a 'factory built' model, (If by factory built you mean made by the manufacturers to work out of the box). You're best bet is to get one that can be or is hard modded as handset hacks can easily be removed via firmware upgrades.
Depends how much you want to spend but theres a few choices out there.
skk3
Try having a look here
