Looking for More Comfortable Replacement for Sennheiser HD280 Pro
M
machi4velli
I have been using the Sennheiser HD280 Pro and I do like them, but they become a bit uncomfortable after a while. Could anyone recommend a more comfortable closed headphone with similar performance? The external noise blockage is important to me, so is it possible to block as much with headphones that do not clamp onto the head as tightly? Anything 75 GBP or less would be fine.
Thanks.
mattski73
hi there,
i've just ordered from audiocubes.com who are based in japan. I'm curious and i want to see how it goes first, before i say go ahead.
however at aournd £75 iwas thinking about the Audio-Technica ATH-ES7. i have no idea how they sound, but if you buy from audiocubes, it's one heck of a saving.
it works out to be £76.4216
http://www.audiocubes.com/product/Audio-Technica_ATH-ES7_Portable_Headphones.html
i feel more comfortable telling you about my experience first, just so there's no problems.
