Looking for low-cost proj screen
Discussion in 'Projectors, Screens & Video Processors' started by TheBoingoBandit, Jul 14, 2003.
  1. TheBoingoBandit
    TheBoingoBandit
    Jul 27, 2002
    779
    28
    +26
    I am thinking about buying an AE100.
    Firstly I'm checking out the prices of low cost widescreen projection screens. I would like one permanently attatched to the wall rather than the pull down manual/electric type.
    The size of screen would be around 6 to 10 foot diagonal(undecided as yet).
    Any suggestions of any good suppliers of good budget screens.
    Thanks in advance!
  2. mortonman
    mortonman
    Have just made my own 7ft 16:9 screen which will fit onto the wall following advice on the DIY section. Got screen fabric from Harkess Hall and although not set up yet, (need the funds) it looks the DB's.
    Overall cost about £180 which is a lot less than if I would have paid for a new one.
    Matt
  3. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Go to your local curtain material supply place and buy a few meters of blackout blind material.
    Build a fram e using 2x1 timber mitred at the corners with cross bracing for strength.
    Build frame.
    Attach Material to frame and then paint Dulux IceStorm Number 5 to get a nice grey screen to improve black levels.
    Total cost about 30-40 quid and if built right will be an amazing screen.
  4. paulefox
    paulefox
    Feb 8, 2003
    1,293
    Bury St Edmunds
    +43
    have a look on ebay I just got one including delivery for £55 and it is great
  5. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    What screen did you get?
  6. Jonny1973
    Jonny1973
    Are you sure it wasn't a roller blind in a previous life?
  7. wozwebs
    wozwebs
    Jul 10, 2003
    1,163
    +112
    I'm using a £44.99 blackout roller blind from Homebase - Does the job great!!
  8. Kramer
    Kramer
    Roller blinds are OK, but they're not dedicated projection screens :p
    OK, an AE100 for £600 probably doesn't warrant an equalivent mount on the screen, but there's no comparison between a blind & proper screen.
    Gain, at best is 0.85/0.9:1.
    Advice would be to get a screen - no point in ruining any PJ with a crappy projection surface.
    Just my opinion - but a good one ;)
  9. Mr Cheese
    Mr Cheese
    Dec 12, 2002
    411
    Down South
    +19
    Gotta agree with you there, Kramer.
    I've just bought a Draper Luma Matt white S from Nexnix (Unbelievably quick service - highly recommended BTW) having used a blackout blind for 3 months. Absolutely no comparision. The picture was good before, now it's alive! Got the AE100 @£799 when the first major price drop occured. But consider £200 on screen well worth it.
    Compare it it to Hi-fi. Would you spend £800 on an amp and £50 on the speakers?
  10. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,438
    Surrey. UK.
    +2,100
    Well, I did buy some Eltax HT2s from RS. ;)
    Gary.
  11. craig@rewind
    craig@rewind
    So does any have anywhere where I could get a screen from for under £70 - max £100 inc delivery please?
  12. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Just to let you know - there is a three or four page article on the merits of actually having a decent/correct screen in the latest edition of Essential Home Cinema.
    Available in all good newsagents now!
    Cap
