Looking for Laptop in £800ish price range
Discussion in 'Desktop & Laptop Computers Forum' started by petemid, Nov 29, 2010.
  1. petemid
    petemid
    Nov 29, 2010
    2
    Hi all, looking for some recommendations please! (sorry if it's a bit long winded!)
    What is your budget - 800ish although can go a bit higher if needs must.
    What size laptop do you want? Between 15 and 17 inches
    Do you have resolution requirements? Deffinitely prefer 1080p
    What will you be using the laptop for? Web design (using Serif Webplus), some HD video editing (does not need to be done very very fast). Some gaming, although again not too fussed. I want the quality of the pitcure whilst watching BluRay to be as good as possible (very important)
    How long does the battery need to last? Not too fussy
    Does it need to be portable? Not really
    Do you require Blu-Ray? YES
    Do you require HDMI output? Yes
    Do you have a preferred brand? Would prefer Dell, Sony, HP etc, but am open minded
    Would you be happy with a refurbished laptop? Would prefer not to
    In Summary -
    I am looking for a pretty decent spec laptop that has a fantastic quality screen for watching BluRay plus HD footage shot on a camera.
  2. zenza
    zenza
    Sep 9, 2003
    2,585
    Midlands
    +222
    Dell XPS 15.
  3. NewBeetle
    NewBeetle
    Oct 19, 2002
    11,552
    NW
    +3,414
  4. petemid
    petemid
    Nov 29, 2010
    2
    Thanks for the replies so far
    How does this compare - comes in at £800
    Chassis & Display
    Enigma II: 15.6" Full HD LED Backlit Widescreen (1920x1080) Super Clear GlossyProcessor (CPU)
    Intel® Core™i5 Mobile Processor i5-540M (2.53GHz) 3MB Cache
    Memory (RAM)
    4GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (2 x 2GB)Graphics Card
    ATI Mobility Radeon HD 5650 - 1GB GDDR3 Video RAM - DirectX® 112nd Graphics Card
    NONEMemory - Hard Disk
    500GB WD SCORPIO BLACK WD5000BEKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)DVD/BLU-RAY Drive
    4x BLU-RAY ROM DRIVE, 8x DVD ±R/±RWMemory Card Reader
    Integrated 3 in 1 SD Card ReaderNetwork Facilities
    ONBOARD GIGABIT LAN & INTEL ULTIMATE-N 6300 WIRELESS - UPTO 450MbpsUSB Options
    4 x USB 2.0 PORTS AS STANDARDBluetooth & Infrared Options
    INTEGRATED BLUETOOTH ADAPTER (£7)Battery
    Enigma Series 6 Cell Lithium Ion Battery (4,800/5,200 mAh)
