looking for ixos component cable for ps2!
Discussion in 'Playstation Forums' started by evilash, Sep 29, 2003.
  1. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    anyone know where i can pick one of these up? i was kinda hoping there was a shop that someone might know in brighton area or within driving distance! failing that online... any ideas...
    thanks in advance!!!!
  2. bash
    bash
    Nov 10, 2002
    2,371
    London
    +322
  3. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Do you reckon this cable is worth the extra dosh? I've just bought the Sony standard AV component cable from Ebay for £7.99, and it's to connect the PS2 to a pana6 plasma. Come to think about it, any one want to buy the cable I just bought? :laugh:
  4. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    i reckon its got to be better.. i did have the cable you have but after only 1 month it broke... (havent got a clue why) with all the cables i have i find the difference between the less expensive range and 'higher quality' to be the same as night and day!
  5. bash
    bash
    Nov 10, 2002
    2,371
    London
    +322
    I got terrible ghosting when I used the standard Sony one on my tosh, switched to the Ixos and it crystal clear. The price difference is justifyable if you want prog scan IMO.
  6. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    thanks bash!
    have managed to get one for £40! not cheap but f***k it! good things cost! mind you so does s***e if it's on ebay!!! he! he!
  7. acucobol
    acucobol
    Sep 7, 2003
    62
    Does your componet cable work for both games as well as DVDs?
    I can only get mine to work with DVDs.
  8. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    the first component cable i had worked for both dvds and games. have you switched the setting in the boot up menu system to yuv! i thinks that's what it was anyhoo.. no idea if that makes the difference but might be the answer!
  9. acucobol
    acucobol
    Sep 7, 2003
    62
    D'oh! Never thought of that.
    Thanks for the info.
  10. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    I thought 8 quid for the cable wasn't bad, and didn't know of any proffessional component cables for the PS2. I do now thanks to bash! So I'll place my order and wait for it (and my panny!).
    No loss, I'll just sell the crap cable with the PS2 when I put my mug face on and buy the silver PS2! Or I could use it and connect it to my pc monitor! Or connect both PS2's together and have a cool split screen action on the panny! That would test the quality of the cables too..
  11. mr chadwick
    mr chadwick
    just out of interest,being that ps2 component are about 1-1.5m long,how do i get one to my pj (ae200) which is in relation to cable length 8m away from my ps2?
    at the moment im using composites with extensions.
    any advice would be really appreciated.
  12. evilash
    evilash
    Dec 11, 2002
    783
    brighton
    +6
    AFAIK i can only think of one way and that's to have a home cinema receiver with component in! i run a gorgeous linn component cable from pj to amp and then i can have three component inputs running into the back of the amp! of course this not a cheap option and i still dont have enough inputs what with all of the below using component:
    pal ps2 x1
    pal xbox x1
    ntsc xbox x1
    pal gc x1
    ntsc gc x1
    pal/ntsc arcam dv88+
    have to say though that its a nice problem to have.......
    there is one other way now i think of it and thats to get a component switcher box! dont know where to find one off top of my head but i am syre someone else will be able to point you in the right direction!
